In the RIO users guide it states the TP Link Archer T1U is compatible with the RIO.
This device is no longer being produced and is replaced with the T2U which I can buy locally.
Before I buy I want to make sure it will work? I assume it will but that’s landed me in trouble before.
Hello! I can’t seem to get the USB WiFi adapter to work. I’ve tried the TP-Link AC600-T2U and the Linksys AC600. The port is enabled, SSID passphrase entered. The MAC address does not show up. I tried a couple of resets to no avail. Any input is welcome!
Thanks
Ah, I had to do a double-take on the adapters you are testing… They are not supported on the RIO.
Here is the user manual list:
The TP link must be the T1U and the Linksys must be the AE6000.
I have tested the T2U and know that it does not work, I have not tested the Linksys, but you already know the answer to that one… The build of Linux we use has limited drivers.
