USB to WiFi Adapter
Hi everyone,
do you guys have a guide on how to set up the wifi adapter?
is the Archer T2U wifi adapter can be use already?
Hi JJ. Welcome to the Opto22 forums.
The RIO users guide has the details you are looking for.
First up, the supported WIfi adaptors are on page 63.
I’ve tested the Archer T2U and know for sure it does NOT work. You will need to get a T1U.
Page 64 then has the first part of your post questions… How to set up the adaptor.
In sort, just fill in the details on the groov Manage Network config page and hit save.
Thanks for a quick response Beno. I will look into it. Cheers!
Another thing, did you configure the wifi adapter while on the ethernet cable connection? is it ok to plug in both ethernet cable and usb wifi?
As long as they are on different subnets, yes, you can run both at once, no problem.
We have a lot of customers doing that.
