Yes. With the soon coming release of PAC Project 10.3 you will be able to use the RIO as remote IO on PAC systems. It will show up just like an EB currently does.
Thanks for the tip on the dead link. Will get the web team on it.
I’m not trying to be a wet blanket or anything, but this hardly covers expansion past one EPIC rack. I mean this is only 10 points of I/O with two of those being relay outputs…
There needs to be something equivalent to the SNAP EB for an EPIC rack so we can expand past one EPIC rack using EPIC I/O modules.
Yes, the ports can be daisy chained. They have the one IP address and act like a two port switch.
Just keep in mind that only ETH1 works with PoE, so if you want to use them with PoE then you will end up with a star network.
Is there a way to retrieve a counter off the RIO via Node-RED? Or is our only option via PAC Control? I’m looking at ways we can leverage the on-board Node-RED for some basic automation.
Hey ya Arlin, take a look at the new groov IO nodes; New groov IO Nodes
They can read point features, like a counter for example.
So yes, using Node-RED, with these nodes, you can read them directly into your flow.
Same question but reading a counter off a SNAP-PAC into Node-RED (slight detour off-topic, I realize)? The PAC nodes don’t seem to support this, or am I missing something?
That should work using MMP.
We just need to double check that the new groov-IO nodes can do MMP with PAC Controllers (pretty sure it can, but I personally have not tested it)
