I am new to node red and JavaScript. I would appreciate help on something I need to get working. I want to send an email to notify me of an alarm condition, based on the status of an I 32 table from my S2. i.e. if value is 1 alarm conditon, 0 no alarm. Please see the attached flow. I have a function block in to simulate my snap pac read node just for simplicity for now.
The only problem i have is that i dont know how to only send the email once, and not every time the flow is injected when an alarm is active.
Any ideas, much appreciation for help on this.
[{"id":"fae1c9a.3fe49b8","type":"inject","z":"c97af0fa.6fb9","name":"","topic":"","payload":"","payloadType":"num","repeat":"3600","crontab":"","once":false,"onceDelay":0.1,"x":288,"y":258,"wires":[["a84d3449.af0e88"]]},{"id":"85f79ab7.071c58","type":"debug","z":"c97af0fa.6fb9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":429,"y":498,"wires":[]},{"id":"a84d3449.af0e88","type":"function","z":"c97af0fa.6fb9","name":"simulate I 32 from SNAP S-2","func":"\n//mimmic the Opto 22 msg.payload\n//set all events to trigger = of zero\nmsg.payload = \n[\n 0,\n 0,\n 1,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0,\n 0\n];\n\nreturn msg;\n","outputs":1,"noerr":0,"x":347,"y":318,"wires":[["8052cd35.8b6aa8"]]},{"id":"ce24e154.f29cf8","type":"function","z":"c97af0fa.6fb9","name":"build email","func":"//Build the email message:\nvar LowAlm = msg.payload; //the I 32 alarm table copied from the Opto controller\nvar R1indextxt = []; //array holding the text for the alarm messages\nvar R1indextxt_final = []; //array holding the alarms that are active\nvar Rindextxt_finalload = []; //array holding the alamrs with the null removed\n\nR1indextxt[0] = \"T1000 low alarm active\"\nR1indextxt[1] = \"T1001 low alarm active\"\nR1indextxt[2] = \"T1002 low alarm active\"\nR1indextxt[3] = \"T1003 low alarm active\"\nR1indextxt[4] = \"T1004 low alarm active and whatever\"\nR1indextxt[5] = \"T1005 low alarm active\"\nR1indextxt[10] = \"T1015 low alarm active and more text\"\n//and so on... up to element 100 or whatever is needed\n\n//map the array to match the read in I 32 table alarm condition to the proper text field\n var format_LowAlm = LowAlm.map((element, index_number) =>{\n //Check the Value of each index and assign a text alarm if equals one\n if (element === 1) \n {\n R1indextxt_final[index_number] = R1indextxt[index_number];\n }\n});\n\n//get rid of the null elements \nR1indextxt_finalload = R1indextxt_final.filter(function(i){return i !== null; });\n\n//msg.payload - the content inside the email\nmsg.payload = \"PPXX Process Alarm ||\" + R1indextxt_finalload.join(\" // \");\n//msg.topic - subject line of the email\nmsg.topic = 'PPXX Process Alarm'\n\n//this can be set in the email node\nmsg.to = []\n//msg.includes = Alarm_active;\nmsg.active = msg.payload;\n//msg.active = Alarm_active;\n\nreturn msg;","outputs":1,"noerr":0,"x":448,"y":434,"wires":[["85f79ab7.071c58","fa4b7c4.ad20b8","d9aa46ab.94a198"]]},{"id":"8052cd35.8b6aa8","type":"function","z":"c97af0fa.6fb9","name":"evaluate array","func":"//evaluate alarm array: does an email need to be sent?\nfunction isOne(One) {\n return One === 1;\n}\n\nvar LowAlm = msg.payload; //the I 32 alarm table copied from the Opto controller\nvar Alarm_active; //boolean to hold status of alarm state: if email should be sent\n\nAlarm_active = LowAlm.some(isOne);\nmsg.active = Alarm_active;\nmsg.payload = LowAlm;\n\nreturn msg;","outputs":1,"noerr":0,"x":311,"y":378,"wires":[["58e52cc1.67958c"]]},{"id":"58e52cc1.67958c","type":"switch","z":"c97af0fa.6fb9","name":"","property":"active","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":297,"y":440,"wires":[["ce24e154.f29cf8"],["85f79ab7.071c58"]]},{"id":"fa4b7c4.ad20b8","type":"e-mail","z":"c97af0fa.6fb9","server":"smtp.gmail.com","port":"465","secure":true,"name":"","dname":"","x":677,"y":434,"wires":[]},{"id":"d9aa46ab.94a198","type":"debug","z":"c97af0fa.6fb9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":696,"y":491,"wires":[]}]
