Reading string from CSERI-4 channel (using RS-232) in CODESYS
I am using a GRV-EPIC-PR2 with CSERI-4 connected to an ultrasonic welder over RS-232.
Every time the welder runs a cycle, a string of weld parameters is sent over RS-232 which I am able to see in Node-RED with a Serial In node. However, I want the information in the string (which I will parse in CODESYS) to be available as tags in Igntion Edge so am going the CODESYS route instead of Node-RED. I know that there is a way to communicate between Node-RED and CODESYS, but I eventually plan to onboard other PLC-based machines through CODESYS so I would like to remove Node-RED from the loop and keep this as simple as possible.
I have the EPIC-PR2 and CSERI-4 configured in CODESYS, however I am wondering where I can actually map the string sent to a channel on the CSERI-4 to a variable in CODESYS.
The Mapping tab doesn’t show much. I’m guessing there is more I need to do in my program to configure the RS-232 channel on the serial module and read anything meaningful from it, but I’m not sure where to start and I haven’t found much in Opto training other than communicating with digital I/O modules.
I know nothing about the serial module, so hopefully there’s someone else that can chime in. However, there are a couple examples on CODESYS Forge and the CODESYS Store for communicating with serial ports:
If all else fails, you could use MMP to write the string to a scrachpad location (from NodeRed) that could then be read in CODESYS using the MMP Function Blocks - that seems a little “Hacky” though.
This may be the same example project, but it also provides the documentation in the codesys help site.
If you are using Node Red and want to send/receive information from Node Red, you would use the OPC-UA Node in Node Red and configure the Symbol Configuration object in Codesys. The first half of our online training section on Codesys OPC-UA connectivity covers this.
Thank you Garrick.
Looks like the newest version of node-red-contrib-opcua is incompatible with my version of Node.js (v14.20.0). I found the most recent version of node-red-contrib-opcua that is compatible with v14.20.0, however it does not have the OPC-UA Client node which I believe I’ll need for this application.
Is it possible to update the version of Node.js that’s on the Epic?
I posted a link to a forum post on installing legacy nodes, which you need to do with the OPC-UA Node.
I went to the version history for node-red-contrib-opcua and kept walking back a version until I found the most recent version that was compatible with Node.js v14.20.0.
However the older version of node-red-contrib-opcua is missing the OPC-UA - Client and OPC-UA - Server nodes.
@matt.karee Your first post makes a good point of not wanting to use Node-RED just to read the serial data and pass it to Codesys.
I suggest that you don’t spend any more time trying to install the opcua node as you should be able to shut down node-red totally (for this application at the very least).
Makes sense, I will go the CODESYS route then.
Do you know if I can treat the CSERI-4 serial channels in CODESYS like I would treat a serial COM port?
I’m looking at this Serial COM example and not seeing how this would apply for the CSERI-4 but I probably just need to do more research on serial communication in general.
You can find the codesys port numbers under System->Serial Devices in groov Manage:
you can then configure that in Codesys:
Then it is just calling the functions in your code, depending if you are using STL, FB, LD…
