I’m battling a connection issue through a groov epic pr1. I am trying to use an openVPN tunnel to access a full Ignition gateway on a different network.
I have the VPN coming into eth0 and I can access the pr1 through it. I have eth1 setup on 172.168.10.10 with the Ignition server at 172.168.10.100, both subnets 255.255.0.0. I have port forwarding trying to route tun0 on eth0 port to eth1 (see rule below).
Not sure what I’m doing wrong here, but I can’t seem to make it work. I have tried different external ports that ignition uses with no results.
I have no configuration in Ignition currently. It is a default gateway running in trail. Trying to make the connection and understand it better before deployment.
What IP address are you using in your browser to try to connect to Ignition?
It will need to be the IP of the VPN interface on the EPIC and the port number you are using to redirect.
Something like VPN IP:port → through EPIC → Ignition gateway IP:port
I have tried that IP as well as the 172.165.10.100:8088 with no luck. I have also tried the VPN public IP. From what I have read on Ignition, ports 8043 and 8060 are for Ignition edge and 8088 seems right but I’m not exactly sure. However, I did try those ports as well.
I really need the designer to find the gateway, and be able to land o. The gateway page for remote configuration. So far my designer has not found the gateway, and I haven’t been able to land on the gateway page.
Below is the port references I have been working with.
I think @gerhardK has the answer. You will need to ensure that port 8088 is open for the VPN tunnel so you can come in on port 8088 over the VPN to the EPICs IP address and go out to the designer IP address using port 8088.
Use the VPN IP address that lets you view groov Manage. You said you had that working. Once you can view the groov Manage pages over the VPN, just add :8088 and you should pop out the port redirect to your Ignition computer, and the designer should launch on your PC as expected.
I did forget to set the firewall port up , but I can not create a rule for 8088. I get an error from the pr1 stating that 8088 is “resvered for opto rules”.
I changed the Ignition server to port 8080 and reset the gateway and still can not connect through the VPN. I know I’m missing something easy here, but just missing it.
Let’s loop @greichert in… I’m thinking I’m missing something on the Ignition Designer side of things…
Its all looking good, right up to the point where it does not work!
I have edited my two earlier posts to clarify that you must use the VPN IP address to view groov Manage and the VPN IP:port to be redirected to the Ignition gateway.
The incoming port (8080) that you are using in the redirect must also be opened to the VPN, which your screenshot shows you do have open (to everything—once you get it working, you can close off all the other interfaces and leave tun0 open).
