Groov RIO 3.3 Firmware Has Been Released
Just in time for your Thanksgiving weekend.
groov RIO firmware goodness.
This release is pretty much in lock step with the EPIC 3.3 firmware, many features are the same on both platforms which is how we try and do things.
Lets bullet point the highlights super quick:
  • Users can now be configured with a global or per user session timeout value.
  • Moved the Network option out of the System page and onto its own menu button.
  • Broke out the Network Diagnostics link into each function with their own menu buttons.
  • Static routes added to the Network options.
  • Add support for GRV-R7-I1VAPM-3 version of the RIO. Its a three phase power monitoring RIO. (Lots more to come about this RIO-EMU soon).
  • Modules menu button was renamed I/O. Added I/O Services link at the bottom of the page.
  • Moved the I/O Reference button to Info and Help menu.
  • Ignition Edge version was updated to 8.1.11
  • Seamlessly re-authenticate openVPN client after session expiration.
  • Node-RED.
    • Added new user type for Dashboard access only (can not view or edit flows).
    • Added the option to launch the Node-RED dashboard at first login.
    • Upgraded Node-RED to version 2.0.6 and Node.js version to 12.22.1
  • Some nice bug fixes.
Note. Each RIO has its own firmware download page. Be sure and get the right one for your hardware.
RIO-MM1 is here: Opto22 - GRV-R7-MM1001-10 Firmware
RIO-MM2 is here:Opto22 - GRV-R7-MM2001-10 Firmware
