Connect groov view to samsung TV
GREETINGS,
Is a new topic here. We planning to use 2 Samsung SmartTV connect to the router and open groov view via web browser that pre-installed in the TV.
Everything work fine until login to the groov manage, it will keep loading like below image. Why is this happen?
I’ve gotten stuck on that loading screen in Safari on macOS before: usually just hitting Refresh fixes it. Any chance that helps?
Also, if you haven’t yet, make sure your TV is running the latest available firmware.
You might find some other tips and tricks in this forum thread;
@Jonathan_Fischer @Beno
Refresh is not helping. I know what is the problem. After I switch to groov view as first page in EPIC then only I can access. Groov Manage not allow me to access because TV not an OS I think.
