Access File System via CODESYS
Welcome to the forums!
This is a Linux file system permissions issue.
The user that Codesys is running as does not have permissions to the file system directory you are using.
Its the same issue here:
Grab yourself a free shell license (if you have not done so already) from here:
https://www.opto22.com/products/groov-lic-shell
Tweak your permissions and you should be up and running in short order.
