Has anyone used the SysDir and SysFile libraries to access files on the groov-EPIC via CODESYS?
I have a recipe tool that I wrote for another CODESYS based PLC that stores the recipes in a file. I could access a folder on that device by using this syntax for the folder: “\MyFolder\Recipes”.
I have created the folders and copied my files onto the device (from the IDE), but when I try to access the folder in code, I get an invalid handle.
This is a Linux file system permissions issue.
The user that Codesys is running as does not have permissions to the file system directory you are using.
Its the same issue here:
