Why is there a break in Groov's trend curve?
Why is there a break in Groov’s trend curve?
use interactive trends.
I have found that its often caused by using an update rate that is too fast.
A browser refresh will redraw it complete.
Lastly, in combination with the update rate, running groov View on a slow computer (eg Raspberry Pi) can cause the breaks in the trend to occur more often.
Sometimes when the device I am trending is remote from the groov and there is a network failure I see this happen.
The problem is found, it is a network problem, and it has been solved. Thanks!
