I have started to log my water use at home.
We installed a 1 pulse per gallon water meter, the output I have put to my EMU.
(Yeah, it shows up as Kw in the EMU Sensor Manger software, but I don’t use that, I use groov to look at the data, so I don’t care what it gets labeled in the EMU - as long as the scaling is right, 1 pulse per gallon sure sounds like 1 pulse per Kw).
Since the whole family looks at the data, I needed it to be a little friendly, so I have a day of the week table, and a month long table (31 days) and then a year long table (12 months).
This way we can keep track of day to day use, and see how we are going over the month.
I probably should bump this out to something like the last 5 years, so we can compare this years use with last years… If you cut the code for that, be sure and post it here! (Please).
Here is how I went about it…
// Get the year/month/day in one transaction (so we avoid any problems w/values
// rolling over between individual reads)
// For the GetDateTime command: 0 = month, 1 = day of month, 2 = year,
// 3 = day of week, 4 = hours, 5 = minutes, 6 = seconds, 7 = milliseconds (unused)
// This command requires 9.1 or newer PAC Control and PAC firmware:
datetimestamp_status = GetDateTime(ntTimeTable);
// Year
NumberToString(ntTimeTable[2], sTemp);
while (GetStringLength(sTemp) < 4) sTemp = "0" + sTemp; wend // Pad with 0s
sDateTimestamp = sTemp;
// Month
NumberToString(ntTimeTable[0], sTemp);
while (GetStringLength(sTemp) < 2) sTemp = "0" + sTemp; wend // Pad with 0s
sDateTimestamp += "-";
sDateTimestamp += sTemp;
// Date
NumberToString(ntTimeTable[1], sTemp);
sDateTimestamp += " "; // put a space after the date, before the time
// Hour
NumberToString(ntTimeTable[4], sTemp);
// Minute
NumberToString(ntTimeTable[5], sTemp);
sDateTimestamp += ":";
// Second
NumberToString(ntTimeTable[6], sTemp);
seconds_since_midnight = GetSecondsSinceMidnight();
// get the current water count from the emu so we can see the use go up through the day.
GetIoUnitScratchPadFloatElement(EMU, 119, water_use_live_count);
water_daily_use = water_use_live_count - water_usage_daily_snapshot;
// get the daily water usage each night at midnight
if (seconds_since_midnight == 0) then
// get the current daily count and put it into the daily snapshot
water_usage_daily_snapshot = water_use_live_count;
water_weekly_use[ntTimeTable[3]] = water_daily_use;
//yeah, its sorta a duplication from what we just did, one table is weekly, the other monthly.
// get the current daily snapshot and put it in the monthly table
water_monthly_use[ntTimeTable[1]] = water_daily_use;
// Now check if we are at the start of the month. If so, add up the whole month and put the total in the yearly table.
if (ntTimeTable[1] == 1) then
water_yearly_use[ntTimeTable[0]] = 0;
for n1 = 1 to 31 step 1
water_yearly_use[ntTimeTable[0]] = water_yearly_use[ntTimeTable[0]]+ water_monthly_use[n1];
next
// Ok, now that we have added up the whole month, clear it. This way we don't have to keep track of 29 day years.
MoveToNumTableElements(0, 0, 31, water_monthly_use);
endif
// set the controller time once a day
time_zone_status = SetTimeZoneConfiguration("PST1,11,0,1,0200/PDT,3,0,2,0200");
time_sync_status = SynchronizeClockSNTP(5, time_server_url);
// Just do all the above once a day
delayMsec(1000);
endif
Please note, I have only just done this code and its working over the past week, but I have not had a new month roll over yet.
So, if you see a bug, let me know quick!
I put the code in place so we can start the new year logging data.
Enjoy.
