VPN Status using API
Hello, attempting to pull status of VPN connection. Looking at the API documents there’s a documented way to enable or disable the connection but not something to view/display the status. What’s the best practice here?
/api/v1/system/network/vpn/openvpn/enable
Hi James,
Welcome to the Opto22 forums!
Best way to do that is to monitor the VPN IP address.
Here is a Node-RED flow that provides this (and other device health data).
You can get that IP a few different ways, so if Node-RED is not going to work for you, lets know what other options you have.
This endpoint will get you all the info that is on the network status page:
Cool, so i’ll pull from that network object then. tx
