HI Guys,
I have a network problem with a Groov Epic and a Modbus device within the same network. Currently, my setup has the Groov Epic connected to a VPN Switch with an IP address 192.168.140.XXX, this VPN switch is connected to a router that uses an IP Address 192.168.1.XXX for network extension. And to this extended network, i have a Modbus device connected.
I had setup the whole network so that i can cross communicate between both of them, i can see the Groov Epic and also the Modbus device (IP Address 192.168.1.100) without no problem. But, once i get into the Groov Epic Node red or Groov View, there is no communication between the Groov Epic and the Modbus Device.
I made sure the firewalls for ETH0 are open to all connections (since its all a private network). i can ping both devices from my computer, but i am not able to ping from Groov Manage to the Modbus Device.
Im wondering if there is something that i am leaving behind in order to get this in.
thanks
