Morning all,
Been experiencing a small challenge and wanting to establish if it can be done this way, or if I am doing something wrong.
What I am trying to achieve is to pass the name of a table in some script that I have written as a string variable:
- Returns a argument#0 error when compiling
Table_Name = RECIPE;
Table_Name_Len = GetLengthOfTable(Table_Name);
- No error when compiling, however does not write value to table element.
Recipe_Value = 150;
Table_Name[0] = Recipe_Value ;
Can this be achieved ?
If I declare the actual name of the table. RECIPE[0] = Recipe_Value, the data is stored
All data types are matched.
Kind Regards
Robin
Welcome to the wonderful world of “Needing to Use Pointers”.
Basically what you’ll do is to find the table by name using ‘GetPointerFromName’, with the name being the name of your recipe (Chili or somesuch), that’ll give you a pointer to the table. To use that pointer, you’ll ‘dereference’ it by putting a * in front of it, which means ‘do what I’m asking with the thing pointed at by this pointer, not to the pointer itself’. So if you say ‘*mypointer = 12’, you’re not setting the pointer variable to 12, you’re setting the variable pointed to by the pointer to 12. Hope that’s clearer than mud.
So here’s the sample. Have a float table named ‘Chili’ defined, a string named ‘s_RecipeName’, a float named ‘f_RecipeValue’, an int32 named ‘i_RecipeValueIndex’, and that really fun and scary pointer named ‘tp_TablePointer’ with a pointer type of ‘Float Table’, because that’s what we’re going to ask it to point to.
// set up some variables for this test
s_RecipeName = “Chili”;
i_RecipeValueIndex = 3;
f_RecipeValue = 25.4;
// get a pointer to the recipe table for your recipe
GetPointerFromName(s_RecipeName, tp_TablePointer);
// using the pointer, dereference it and pop a value in the right index
*tp_TablePointer[i_RecipeValueIndex] = f_RecipeValue;
If all goes well (and it did when I test ran it), your ‘Chili’ table should end up containing ‘25.4’ in index 3. As a side note, you really really should check the pointer for NULL before you write something using it. I didn’t do that here, because, well… I’m lazy.
Hi Todd,
Thankyou for the advice and “pointing” me in the right direction. Ha Ha
The way you have explained make sense and I will give it a go in the next day or two.
Appreciate the input !
Best Regards
Robin
