Hi, I am working on Groov EPIC PR2 and want to connect to Azure-IOT-hub because my company uses azure for streaming and visualizing sensor data. When I try to install node-red-contrib-azure-iot-hub 0.5.3 i got the following error. Can someone help here on this. Error log is added here for reference.
024-03-20T08:16:17.120Z Install : @nodecolor/node-red-contrib-azure-iot-hub 0.5.3
2024-03-20T08:16:18.366Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict @nodecolor/node-red-contrib-azure-iot-hub@0.5.3
2024-03-20T08:16:45.854Z [err] npm
2024-03-20T08:16:45.855Z [err]
2024-03-20T08:16:45.855Z [err] WARN registry Using stale data from https://registry.npmjs.org/ because the host is inaccessible – are you offline?
2024-03-20T08:16:45.857Z [err] npm
2024-03-20T08:16:45.857Z [err] WARN
2024-03-20T08:16:45.858Z [err] registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
2024-03-20T08:17:04.701Z [err] npm
2024-03-20T08:17:04.702Z [err] ERR! code ENOTSUP
2024-03-20T08:17:04.788Z [err] npm
2024-03-20T08:17:04.788Z [err] ERR! notsup Unsupported engine for @azure/event-hubs@5.11.3: wanted: {“node”:“>=18.0.0”} (current: {“node”:“14.20.0”,“npm”:“6.14.17”})
2024-03-20T08:17:04.788Z [err] npm ERR!
2024-03-20T08:17:04.789Z [err] notsup Not compatible with your version of node/npm: @azure/event-hubs@5.11.3
2024-03-20T08:17:04.789Z [err] npm
2024-03-20T08:17:04.789Z [err] ERR! notsup
2024-03-20T08:17:04.789Z [err] Not compatible with your version of node/npm: @azure/event-hubs@5.11.3
2024-03-20T08:17:04.789Z [err] npm ERR!
2024-03-20T08:17:04.789Z [err] notsup Required: {“node”:“>=18.0.0”}
2024-03-20T08:17:04.790Z [err] ERR!
2024-03-20T08:17:04.790Z [err] notsup Actual: {“npm”:“6.14.17”,“node”:“14.20.0”}
2024-03-20T08:17:04.835Z [err]
2024-03-20T08:17:04.835Z [err] npm ERR! A complete log of this run can be found in:
2024-03-20T08:17:04.836Z [err] ERR! /home/dev/.npm/_logs/2024-03-20T08_17_04_795Z-debug.log
