I am trying to connect from Node Red (Within an EPIC) to a SNAP PAC PLC that’s within our network. I was able to get the API Name and Key, but i am still getting an error that says DEPTH_ZERO_SELF_SIGNED_CERT.
From what I read, seems to be missing a SSL Cert. Been trying to create one, but i haven’t been successful yet. What do you guys recommend for this instance? Whats the easist way to create a cert?
HTTPS slows a SNAP PAC Controller down a bit, since it sounds like you are on the same network, you don’t really need to take that hit in performance for some unneeded encryption.
From PAC Manager looking at that SNAP PAC Controller, make sure your HTTPS is turned off from Communications → Network Security
Unless you have an open firewall to the PAC (hope not!), then your https outbound connection to AWS has nothing to do with the HTTP/S setting on the PAC, so you can use HTTP for Node-RED and HTTPS in the PAC Control comm handle to AWS.
But that is a big assumption from me that that is how you have it setup.
Is your HTTP connection using port 80?
Check in PAC Manager, when using Node-RED it MUST be port 80. The screen shot I posted in this thread was when I was testing some other code and so I moved it to 8080.
