What are your recommendations on transducer safety… How should I configure program if my tranducer goes bad?
So that my water levels or pressures don’t go out of wack?
How are you programming the logic?
Also, are you going to be using a PID loop?
There are different ways to check and branch in the software depending on what software you are using.
