I am trying to configure several GRV-ODCSRC-24 to run as TPO using python and OptoMMP. Unfortunately, I have not found the memory addresses on the OptoMMp guide. Going through the Forum I found the following:
alberto.bueno brings up some good points. Are there any plans to have the TPO memory map addresses documented? I’ve ran into similar issue in the past and had to get the “secret” addresses.
Honestly, its hard to commit much time to it. We about 1 request every 5 years.
Most people use PAC Control and it just works there with no faffing about.
That said, I am always happy to run it up the flag pole and see what the team thinks.
I can imagine that for industrial automation PAC control, Codesys, etc. are the way to go, and in most of the cases, it is enough. My engineer background coupled with my research makes it ideal to be able to program using Python, in this way (ideally) you will not be constrained.
One of the reasons I purchased the groov EPIC platform was the shell access. My mistake was thinking I was going to have a fully documented memory map and a less constrained Linux system. Perhaps, it would be important to mention those limitations upfront!
Anyways, Opto22 and community support have been exceptional and there is always a solution. I only hope that the system keeps evolving and in the future doing Python implementations is a standard feature of the system.
