Touch Screens - Resistive or Capacitve
#1
Can the Epic system work with either Resistive or Capactive touchscreens? What about touch screen calibration, is the Epic system capable to run calibration routine?
Thanks
Dave
#2
Currently the EPIC works with Projected Capacitive Touch screens only. The issue is with the calibration, and the PCAP touchscreens do not require calibration out of the box. We are working on incorporating a calibration method into groov Manage to accommodate the standard resistive screens. Also, be aware, that you could also have display issues when using a converter(HDMI to DVI/VGA). Some have had success, while others have not. For consistency, it is recommended that the display being used have a native HDMI port.
