I know how to display an image file get from http using Python in groov view.
Please teach me the directory where I can access the groov view or how to browse the home directory from groov view.
Can I just get a little better understanding what are you looking to do here please?
I think you are saying that you have a Python script that is getting an image from some where and you want to show that image in groov View using the Video Gadget?
EDIT: If where you are getting the image from has a web address, you can just add that to the groov View video gadget.
You can read about how to use the video gadget here in this blog I wrote in 2015… Still applies today.
Yes, I have the Python script and store image files in my EPIC home directory.
I want to display these files on groovView.
I hope you read the blog I linked.
You can see that in order to display the image in groov View, the image needs to be hosted on a web server such that you can use a URL to view the image.
EPIC does not have such a web server that the shell user can access, so we need to make one, we will use Python to create a small web server for the image.
From shell copy paste each of the following lines (one at a time).
Do not proceed if any line causes an error.
Update the EPIC repo, install python-pip (you may have this already, I don’t know. Tip: do not update PIP, ignore the warning) and then install the module http which is the python web server:
sudo apt-get update
sudo apt-get install python-pip
sudo pip install http
Now we create the bash script that will use Python to make the webserver:
nano web.sh
Copy the following into the editor, save with ctrl+o, enter, then ctrl+x
#!/bin/sh
# The image path needs to be explicit.
# Image must be a JPG, BMP, PNG or GIF.
~/epic.png
reass=$!
killer(){
kill $reass
exit
trap killer INT
python -m SimpleHTTPServer 8888
kill $reass
Now make the script executable.
chmod 766 web.sh
Lastly, run the script:
nohup ./web.sh &
Open groov View, go into build mode, add a video gadget and add the URL for the image like this:
Swap out ‘lcben’ for your EPIC host name.
Please note the following VERY IMPORTANT things.
Please report back how this works for you.
