Hi,
Is there a way to display an image (for example a 3-way valve) with a different indication/position using 2 tags?
Thanks
Hi,
Thanks
Use two images and the visibility binding to select which one is visible.
Hi Michael. Welcome to the forums.
Just as @philip said, use two images in the image gadget.
You might be able to find the two pre-drawn ready to go in our SVG library…
https://www.opto22.com/support/resources-tools/demos/svg-image-library
