I just installed the SSH license & Enabled the SSH. We will be adding various python and other scripts to run in our Groov Epic project. I am somewhat familiar with Linux script, command line, etc. My question is; How does on open the EPIC PR1 Linux desktop/interface? I cannot locate this in any of the various Epic related user manuals. Thanks Dave
Oh, okay. I think I remember how to install Putty on my Win10 laptop. I’ll check, but is there some step-by-step documentation to do this, in case I can’t locate it. Thanks
You can download the msi installer and run it, or just the putty.exe and run it without having to install it.
Run putty, type in the IP address of your PR1, select SSH, and click open. It will then open the terminal windows where you can type in your SSH username and password that you setup from manage.
Windows 10 Command prompt or Powershell both support the ssh command, therefor you can just use ssh username@ipaddress to shell in. No need for putty.
Now if you happen to forget the password you set up for SSH this is not fun. I just did this. So I think I have to do a hard reset on the machine to clear it. Can anyone confirm that?
If you have forgotten, there is a bent paper clip in your future.
(Don’t for get to backup everything first! Refer to our guide if its your first time, or if you are a bit rusty).
a Few things related to this, I noticed some PR1 would stop shell access, and it would have to be reconfigured from scratch, at least 2 on the field that were previously configured, had to be re-configured, is this normal behaviour? in addition, would the ssh configuration survive firmware update? similarly, if a firmware update, with no backup, is performed, would that reset the SSH username/pw? thank you
