SNAP-SCM-CAN2B with DeviceNet
Hello fellow Opto users.
I’m working on a big project where I need to integrate DeviceNet network to our excising Opto code/system. Previously it’s was done using gateway and we pulled data from it, however I’m wondering if I can use SNAP-SCM-CAN2B to talk to DeviceNet directly, without gateway and associated overhead.
DeviceNet utilize CAN protocol, with certain differences, so theoretically it should be possible. I’m still learning on the details, but I would greatly appreciate any comments from more experienced users and gurus of industrial automation.
Thank you,
Sergiy
Sergiy - Have you considered using a Devicenet to Modbus-TCP gateway? I realize it adds extra expense, but it might save on engineering time. Here is an example of of one:
Hi Arun, thank you for suggestion.
Yes, that’ exactly what we are using right now. I was wondering if this can be done only Opto hardware as a physical layer is the same.
The difference only in protocol, or I got it wrong?
Thank you,
Sergiy
Sergiy,
I’m sorry I can’t be of more help. None of our customers or team here have experience in trying that.
Hi Sergiy, did you manage to implement DeviceNet protocol using SNAP-SCM-CAN2B ?
