Setting up new EPIC but unable to load strategy (wifi connected EPIC)
Just set up a new EPIC, only this one is not connected to our network via ethernet, but via wifi. We traditionally assign each EPIC a static IP via ethernet, but in this case, we connected via Wifi and used DHCP. It is on the LAN at 192.168.10.244 and we were able to successfully update the firmware to the latest, so we know it can access the Internet, we can log into the UI, etc.
In PAC Terminal, this is what I see:
and drilling down into the messages for 10.244 EPIC, I see the error re: the Ethernet socket error (10057), for which I found a lot of forum posts about, but they all go into the networking aspects. Is there something I need to change in groov Manage to allow me to load a strategy when the EPIC is connected via DHCP and via Wifi?
I’m guessing here in the Security → Firewall…
(Don’t forget to click ‘Save’ after you make the change and you might want to also change it for port 22001 as well)
That did it! Thanks @Beno
After making the above change (incl port 22001)…
and then after downloading from PAC Control…
