Hello, I am a .net programmer and I am developing a desktop application that display in a chart data acquired through sensors connected to an epic groov. My application use a SQL Server database to store data before displaying. So I need to send data from Epic every time it makes an acquisition from sensors. I can see there are many way to program the epic system, what is the best way to achieve this continuous communication between the two systems?
Regards
Yup, just as @Jakes said, the best way forward here is to use the built in Node-RED.
Turn it on via groov Manage, then once its running, click the open editor link.
If you want to start from zero and get up to speed on Node-RED, then watch this video (all three parts).
You will then need to install the PAC Control nodes and the MSSQL node.
Once you have those two sets of nodes installed you can then start small and drag a PAC in node onto the canvas.
Next to that put a function block, then lastly, your MSSQL node.
Wire the three together and then start filling in their details.
