Hi,
I have two Epics, call them A and B.
In Epic A I have the IO unit of Epic B setup for Generic OptoMMP (I also tried as a PR2). From PacControl strategy in unit A, I use various get/set I/O unit scratchpad commands referencing unit B’s scratchpad via the IO mapped above. This is all over local isolated network, no routers, no internet.
It works.
What I can’t tell is 1) Is it UDP or TCP. I see it is using port 2001, and I’m guessing its UDP as I don’t see an open connection listed with netstat that describes it. 2) If it is UDP, can it be made to use TCP? I see generic MMP docs that suggest either works, but perhaps PacControl only uses UDP for these commands? 3) If it can be made TCP, will it inherit/use the SSL certificates from the Epic to encrypt the connection?
I’ve read relevant areas in 2267, 1700, and 1701 as well as searching the forums. I don’t explicitly see this discussed, perhaps I’m missing it.
