Philip and Mary are correct. Feed the array into the Split node, use Range to scale the values, and Join to put the values back into an array. Finally, send the array to your PAC.
Here’s an example using an Inject node with a JSON array payload of 6 integers, splitting, ranging to 0-100%, and finally joining them back into an array:
[{"id":"3d4f2829.b249f8","type":"inject","z":"a307d805.d13d58","name":"","topic":"","payload":"[8626,8516,7734,9178,10023,1234]","payloadType":"json","repeat":"","crontab":"","once":false,"x":150,"y":280,"wires":[["561855d4.dc126c","983c5995.7e6268"]]},{"id":"1d0a1b62.595df5","type":"range","z":"a307d805.d13d58","minin":"0","maxin":"10000","minout":"0","maxout":"100","action":"scale","round":false,"name":"Scale to 0-100%","x":570,"y":280,"wires":[["aaa03dfc.f0f3","ddbfa1f.3f12c6"]],"inputLabels":["testin"],"outputLabels":["testout"]},{"id":"1c3282e8.13c95d","type":"debug","z":"a307d805.d13d58","name":"","active":true,"console":"false","complete":"true","x":910,"y":400,"wires":[]},{"id":"983c5995.7e6268","type":"split","z":"a307d805.d13d58","name":"","splt":"\\n","spltType":"str","arraySplt":"1","arraySpltType":"len","stream":false,"addname":"","x":330,"y":280,"wires":[["57773b6c.2d2c24","1d0a1b62.595df5"]]},{"id":"ddbfa1f.3f12c6","type":"join","z":"a307d805.d13d58","name":"","mode":"auto","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"10","x":790,"y":280,"wires":[["1c3282e8.13c95d"]]},{"id":"561855d4.dc126c","type":"debug","z":"a307d805.d13d58","name":"","active":true,"console":"false","complete":"true","x":290,"y":400,"wires":[]},{"id":"57773b6c.2d2c24","type":"debug","z":"a307d805.d13d58","name":"","active":false,"console":"false","complete":"true","x":470,"y":400,"wires":[]},{"id":"aaa03dfc.f0f3","type":"debug","z":"a307d805.d13d58","name":"","active":false,"console":"false","complete":"true","x":730,"y":400,"wires":[]}]
Here’s an image of the flow:
Good luck! -Benson
