Does anyone know a part number for the power plug on a SNAP-PAC-S2 Controller? I have one with a broken + terminal and am looking for a replacement.
Normally, I ask support for the number, or sales. If that doesn’t work, I simply get a nice magnifying head set and a bright light, and look the part over really good. Usually there is a set of numbers you can get, either from the female or male side, then look it up on Digikey.
Phoenix Contact usually has a model that is close enough. If you cannot find the exact same unit, then measure with a caliper the pin diameter, pin spacing, and offset distance of pins, then look up a model of Phoenix Contact male and female mating pair that will fit through the cover plate hole. Then take the board out and desolder and resolder the new one.
Opto22 will repair the unit for half the price of a new one, but if that makes you squirm, then send it to me and I’ll fix it.
Thanks Barrett. I looked one up on Digikey. not exactly the same but it works.
