Now that we have RS-232 communication what’s the best way to filter out our receive data? We currently receive:
@253ACKATM;FF
The info I need is the ATM but that can vary depending on the pressure reading. It can vary from three characters to twelve characters.
Would I use a string table for this?
Thanks!
Shawn
The characters will be a mixture of numbers and letters.
I think I have to break it into two steps right? One where I remove the ;FF and one where I place the rest in a table starting at character 8?
As long as the characters will not include “;
” you can use that as a marker to grab your information. One way to do this would be to find the index of that character and then grab all the characters after the “K
” up until that index, so that it works even with longer or shorter strings.
Here’s a quick example that should do what you’re looking for:
// Find the index of the ending character ';'
end = FindCharacterInString(';', 7, MyString);
// Save the substring from index 7 to ';' into "info"
GetSubstring(MyString, 7, end-7, info);
Also, this is assuming your “@253ACK
” will not change – is that the case? If that is going to get shorter or longer at any point then you’ll need to add an extra step.
