I’m having some reliability issues with reading and writing the memory map with Modbus on the RIO. It works fine for a while, but eventually stops communicating and stops taking new connections. I’m actively working on a project with this RIO using Ignition / node-red / OptoMMP streaming / node-red MQTT / modbus so I may have some self-inflicted issues, but I seem to be hitting some kind of limit in the mmpServer.
I’m using Ignition to talk to the RIO using Ignition’s Modbus driver. This is a connection that occasionally will have packet loss (think vpn over cellular).
I have noticed that the Ignition Modbus driver is very aggressive about reconnecting after a communications failure and that has caused some devices to hang / refuse to accept new connections and I am wondering if the RIO has the same issue with that. Restarting the RIO (or disabling the device in Ignition for a long while and re-enabling) is the only thing I’ve been able to get it going again.
Here is a netstat output when the failure happens:
netstat | grep 8502
tcp 0 0 172.27.72.40:8502 40.83.212.51:63855 ESTABLISHED
tcp 0 1 localhost.localdo:60296 localhost.localdom:8502 SYN_SENT
tcp 0 0 172.27.72.40:8502 40.83.212.51:64605 ESTABLISHED
tcp 0 0 172.27.72.40:8502 40.83.212.51:62362 ESTABLISHED
tcp 0 0 172.27.72.40:8502 40.83.212.51:61713 ESTABLISHED
tcp 0 0 172.27.72.40:8502 40.83.212.51:63111 ESTABLISHED
tcp 0 0 172.27.72.40:8502 40.83.212.51:63456 ESTABLISHED
tcp 0 0 172.27.72.40:8502 40.83.212.51:64236 ESTABLISHED
tcp 0 0 172.27.72.40:8502 40.83.212.51:62734 ESTABLISHED
You can see that there are several connections - these are broken/orphaned connections from an Ignition gateway. The localhost connection is me attempting to communicate from a Modbus node in node-red. It fails to connect as well.
I get this in the Operating System log on the RIO occasionally, which may be related:
2021-04-17T20:10:38.653019+00:00 opto-04-b4-3b kernel: [9138597.259972] TCP: request_sock_TCP: Possible SYN flooding on port 8502. Dropping request. Check SNMP counters.
The OptoMMPServer log occasionally has MB_Wrk messages, not sure what they are.
[2021-04-18 02:31:36] GRV-R7-MM1001-10
[2021-04-18 02:31:36] Copyright (c) 2017-2020 Opto 22
[2021-04-18 02:31:36] Version: R3.0a
[2021-04-18 02:31:36] Build Date: 11/25/2020
[2021-04-18 02:31:36] Build Time: 21:37:08
[2021-04-18 02:31:36] Default scheduling policy is normal (non real-time).
[2021-04-18 02:31:36] [Creating Threads ...]
[2021-04-18 02:31:36] Using BootId=47
[2021-04-18 02:31:37] Reopen USB connection.
[2021-04-18 02:31:37] Failed to open communication with /dev/usb_rio.
[2021-04-18 02:31:38] Reopen USB connection.
[2021-04-18 02:31:38] Delete module at slot 0 of type 0.
[2021-04-18 02:31:38] New module at slot 0 of type f0000022 with 10 channels.
[2021-04-18 02:31:38] Modbus/TCP Server threads down-grade to normal scheduling policy.
[2021-04-18 02:31:38] MMP Server threads down-grade to normal scheduling policy.
[2021-04-18 02:31:38] O22Timer threads down-grade scheduling priority to 1.
[2021-04-18 02:31:38] [Running ...]
[2021-04-18 02:32:28] Power Up Clear Received.
[2021-04-18 02:34:53] Manual Store to Flash.
[2021-04-18 02:36:38] MB_Wrk00 Status: 0
[2021-04-18 02:36:38] MB_Wrk00 Rx error: 0
[2021-04-18 02:36:38] MB_Wrk00 Header packet len: 1536
[2021-04-18 02:37:22] Manual Store to Flash.
[2021-04-18 02:37:57] MB_Wrk01 Status: 0
[2021-04-18 02:37:57] MB_Wrk01 Rx error: 0
[2021-04-18 02:37:57] MB_Wrk01 Header packet len: 2816
[2021-04-18 02:37:57] MB_Wrk00 Status: 0
[2021-04-18 02:37:57] MB_Wrk00 Rx error: 0
[2021-04-18 02:37:57] MB_Wrk00 Header packet len: 1536
[2021-04-18 02:37:58] Manual Store to Flash.
[2021-04-18 02:38:09] MB_Wrk01 Status: 0
[2021-04-18 02:38:09] MB_Wrk01 Rx error: 0
[2021-04-18 02:38:09] MB_Wrk01 Header packet len: 2816
