So here’s a long response… with a couple options to make it more readable.
I’m a big believer in internal variables that tell you what’s going on.
Note that the first assumption I am making is that the HMI is truly toggling between 0 and 1 for the variables named as such. If that’s true, logic writing can be simplified because a value that is zero is considered false, and any non-zero value is considered to be true. This also applies to digital I/O points, the “IsOn” is nice because it lets us know that it’s actually an I/O point, but it’s not required.
Correct me if I’m wrong, but the assumption is that when the pump is in auto, you want the tank to stay above a specific setpoint, and to get there, you want to run it for a set time so you’re above the setpoint and then it can drop back down.
First: without a flag variable – You don’t say when the timer is being set, but if that’s truly what you want you can simply set the down timer when it needs to run. As long as it’s below the setpoint the timer will be continually reset.
if (Storage_Tank_Level <= Low_Limit_Setpoint) then
dt_Pressure_Pump_Idle_Time = Time_To_Run;
endif
if you want to add a hysteresis you can do that by modifying the above
elseif ( Storage_Tank_Level <= Low_Limit_Setpoint + Hysteresis_Setpoint
and not HasTimerExpired(dt_Pressure_Pump_Idle_Time)
) then
endif
But, better yet this could be done with a new flag variable (Auto_Pump_Desired_Flag) and make it more understandable, plus it would allow you to combine the timer with the hysteresis better:
SetVariableTrue(Auto_Pump_Desired_Flag);
elseif ( Storage_Tank_Level >= Low_Limit_Setpoint + Hysteresis_Setpoint) then
SetVariableFalse(Auto_Pump_Desired_Flag);
endif
Based on the logic, even in “Manual” mode, it will not run if High_Pressure_Flag is running, or if the Fire_Pump_SS is true, (or actually if the Storage_Tank_Level is too low either, not sure whether that is by intent or not). Therefore, you might want to add a Pump_Allowed “flag” variable:
Pump_Allowed_Flag = not ( High_Pressure_Flag
or Fire_Pump_SS);
// You may need to add more reasons to run here... your original code has more (e.g. tank level must be above 2 and timer can't be expired) but those seemed incorrect based on your description at the beginning of the message.
Next:
I often use “mode” variables that allow you to set a value and thus display it for HMI, as well as see it instantly when debugging.
for instance, in your case: an option to handle the logic for an HOA is to assign an internal “mode” variable.
if (not Pressure_Pump_Toggle) then
Pump_Mode = 0; // (Off Mode)
elseif (Pressure_Pump_Toggle_SS) then // In order to get here, Pressure_Pump_Toggle must not be zero
Pump_Mode = 1; // (Manual Mode)
else
Pump_Mode = 2; // (Auto Mode)
endif
Then you can use a switch statement
switch (Pump_Mode)
case 1: // Manual Mode
Pressure_Pump_SS = Pump_Allowed_Flag;
break
case 0: // Off Mode
SetVariableFalse(Pressure_Pump_SS);
default: // must be in Auto Mode
Pressure_Pump_SS = Auto_Pump_Desired_Flag and Pump_Allowed_Flag and not
break
endswitch
Note that this would work basically the same if Pressure_Pump_SS is a digital output, but I’d change the Off Mode to TurnOff() instead of SetVariableFalse().
BTW: Looking at your existing logic:
if Pressure_Pump_SS is actually an I/O point, right now it is possible to chatter it (e.g. have it go off, then on again) while executing the current logic: if the pump is in “Manual” and the timer is expired, the first if will turn it off, and the second if will turn it right back on. Since Opto 22 does things with I/O immediately, that will actually turn the point off for a few milliseconds then turn it back on.
