This is the first time I’m using the configuration dialog instead of the memory map to configure TPO PIDs since this capability had been added and I am seeing an issue with the Configure PID Loops dialog.
When assigning a TPO output in the Edit PID Loop, the Configure PID Loops output column displays the incorrect point. I’m not sure if this has an effect on functionality yet.
