Almost 95% of my projects were created with PAC Project version R9.6003-86. On one of my PCs, I must have used a more recent version maybe R9.6004-109, R9.6005-125 or R9.6006-131. First off, how can I tell which PAC Project this PC is running. (sure, I can see Control is R9.6e, Display is R9.6F Build 0092 and SoftPAC is v.R9.6a, but what Project version installed those?) Secondly, can I reinstall R9.6003-86 on this same PC and both versions will work (maybe in a different location on my PC)?
“First off, how can I tell which PAC Project this PC is running?”
If you look at the PAC Project readme file, there is a section that lists all the component versions for each particular PAC Project installer version. Look for the section titles “Application Versions in PAC Project Releases”:
Here are some examples…
You can tell which PAC Project is installed on your machine by going to Control Panel, Uninstall Programs, it tells you the exact version or versions installed on your PC there.
I have multiple versions of PACProject installed and working on my PC at present
