PAC Display Tag Selection Windows
Is there a way to make the Tag Selection window open lower horizontally so that you can see the existing tag you are changing?
It doesn’t seem like a big deal…but when you have a busy HMI it says clicks/time.
-Craig
The way it is now:
What I am asking can be done:
I wonder if there is a registry x,y value that could be tweaked for those windows positions… Hmmm
@ccaldwell Do you have any thoughts about this request?
I will check into that, Craig.
Maybe we can put any currently selected tag name inside the Tag Selection window.
Hi Craig,
Would an addition like this help you out? In the image below, the area highlighted would contain the previously selected tag, if any.
Yes, that would help.
Thank you for bringing this item up, Craig.
This addition will be in the next release of PAC Project.
