PAC Display Configuration/Run time file got Corrupted
Hi all,
I have a Pac Display file, that looks at different analog Inputs and the file got corrupted for some reason. i Can’t open that file with neither PAC Display configuration Pro 9.5 or PAC Display Runtime Pro 9.5. Every time i try to run that File it says the following “Can’t compare PAC Display Versions”, I didn’t update the version for either the control strategy related to that file nor i tried to open the file with a later version. Any Idea on what has happened?
Thank you for your help
For something like this I suggest that you get hold our support team and see if they can help get the project untangled.
