I found some files on my laptop that I’m not sure what their purpose is or how to use them. I think were to update Strategy with Analog Input & Digital Output definitions?
AINS.PAC.DEF & DOUTS.PAC.DEF
Thanks
Dave
Thanks
Dave
Dave,
Just check Program Files x86 → Opto22 → PAC Project xx.x → def
Where xx.x is your pac project version number.
All the def files should be in there.
Don’t delete yours, clearly you had them for some reason, but there should be the same files in that directory path I just mentioned.
Don’t copy them over the existing ones!
I am just pointing out they are important and should already be on your system.
Ben,
You are correct, I found them in the ‘def’ folder for PAC Project 9.0
Thanks
Dave
