@Jonathan_Fischer: nothing too exciting in the contents. Lots of timestamps. Here’s a sample:
"value": "",
"name": "s_3PhaseWarning_Timestamp"
"value": "",
"name": "s_75HPRuntimeWarning_Timestamp"
"value": "High Level Float",
"name": "s_AASumpLevelShutdown_Device"
"value": "",
"name": "s_AASumpLevelShutdown_Timestamp"
"value": "Low Level Float",
"name": "s_AASumpLevelWarning_Device"
"value": "",
"name": "s_AASumpLevelWarning_Timestamp"
"value": "BNA_NiStrike",
"name": "s_AccumHCL_Back_PumpName"
"value": "rft_HCLFeeders_Accum_BNA_NiStrike_Minutes",
"name": "s_AccumHCL_Back_VariableName"
"value": "Dept8_A2Acid",
"name": "s_AccumHCL_Front_PumpName"
"value": "rft_HCLFeeders_Accum_Dept8_A2Acid_Minutes",
"name": "s_AccumHCL_Front_VariableName"
"value": "04/13/2023 10:00:01",
"name": "s_AccumulateRuntimes_Timestamp"
"value": "WEEKDAY",
"name": "s_AirMakeup_CurrentState"
"value": "",
"name": "s_AirMakeup_ProbeQualityWarning_Timestamp"
"value": "Air Makeup",
"name": "s_AirMakeup_TemperatureWarning_Device"
"value": "",
"name": "s_AirMakeup_TemperatureWarning_Timestamp"
"value": "",
"name": "s_AirPressureHigh_Auxiliary_Timestamp"
"value": "",
"name": "s_AirPressureHigh_Plant_Timestamp"
"value": "",
"name": "s_AirPressureLow_Auxiliary_Timestamp"
"value": "04/12/2023 13:44:59",
"name": "s_AirPressureLow_Plant_Timestamp"
"value": "NORMAL",
"name": "s_AirSystem_State"
"value": "Bead Blaster #1",
"name": "s_BeadBlaster1_Description"
"value": "Bead Blaster #2",
"name": "s_BeadBlaster2_Description"
"value": "",
"name": "s_BeadBlasterNoMotionWarning_Device"
"value": "",
"name": "s_BeadBlasterNoMotionWarning_Timestamp"
"value": "Boiler #1",
"name": "s_Boiler1_Device"
"value": "",
"name": "s_Boiler1_FlameFailure_Timestamp"
"value": "",
"name": "s_Boiler1_LowWaterLevel_Timestamp"
"value": "Boiler #2",
"name": "s_Boiler2_Device"
"value": "",
"name": "s_Boiler2_FlameFailure_Timestamp"
"value": "",
"name": "s_Boiler2_LowWaterLevel_Timestamp"
"value": "04/10/2023 05:19:03",
"name": "s_BoilerPressure_Warning_Timestamp"
"value": "",
"name": "s_BoilersOnDuringWeekend_Timestamp"
"value": "Boiler water on too long with no boilers",
"name": "s_BoilerWater_NoBoilers_Description"
"value": "",
"name": "s_BoilerWater_NoBoilers_Timestamp"
"value": "seconds",
"name": "s_BoilerWater_NoBoilers_Units"
"value": "Boiler water on too long",
"name": "s_BoilerWater_OnTooLong_Description"
"value": "",
"name": "s_BoilerWater_OnTooLong_Timestamp"
"value": "seconds",
"name": "s_BoilerWater_OnTooLong_Units"
"value": "",
"name": "s_BoilerWaterFlow_NoBoilers_Description"
"value": "",
"name": "s_BoilerWaterFlow_TimeWarning_Description"
"value": "",
"name": "s_BoilerWaterFlow_Warning_Description"
"value": "MonitorDept3Values",
"name": "s_ChartRuntimeError_Chart"
"value": "",
"name": "s_ChartRuntimeError_Timestamp"
"value": "Daily",
"name": "s_ChilledTank1_DailyDecrease_Description"
"value": "",
"name": "s_ChilledTank1_DailyDecrease_Timestamp"
"value": "Mezzanine Chilled Water Tank",
"name": "s_ChilledTank1_Device"
"value": "Hourly",
"name": "s_ChilledTank1_HourlyDecrease_Description"
"value": "",
"name": "s_ChilledTank1_HourlyDecrease_Timestamp"
"value": "04/07/2023 02:25:29",
"name": "s_ChilledTank1_LevelLow_Timestamp"
"value": "",
"name": "s_ChilledTank1_TemperatureFault_Timestamp"
"value": "Department 3 Chilled Water Tank",
"name": "s_ChilledTank2_Device"
"value": "",
"name": "s_ChilledTank2_TemperatureFault_Timestamp"
"value": "04/13/2023 04:47:48",
"name": "s_ChillerCompressorFault_Timestamp"
"value": "",
"name": "s_ChillerNotNeeded_Timestamp"
"value": "",
"name": "s_CompressorModuleFault_Timestamp"
"value": "-534|Info|(null)|N/A|0|R1_202|07:15:11|04/13/23",
"name": "s_ControllerMessage_Info"
"value": "04/13/2023 07:17:30",
"name": "s_ControllerMessage_Timestamp"
"value": "Dept5_Lane2Sump",
"name": "s_ControlSumpPumps_PumpName"
"value": "hut_Dept5_Lane2Sump_AirPumpRuntimer",
"name": "s_ControlSumpPumps_VariableName"
"value": "Lane 1 Sump",
"name": "s_Dept5_Lane1Sump_Device"
"value": "",
"name": "s_Dept5_Lane1SumpFloatWarning_Timestamp"
"value": "04/10/2023 15:13:00",
"name": "s_Dept5_Lane1SumpLevelWarning_Timestamp"
"value": "Lane 2 Sump",
"name": "s_Dept5_Lane2Sump_Device"
"value": "04/07/2023 11:17:13",
"name": "s_Dept5_Lane2SumpFloatWarning_Timestamp"
"value": "04/13/2023 05:01:06",
"name": "s_Dept5_Lane2SumpLevelWarning_Timestamp"
"value": "04/13/2023 07:00:30",
"name": "s_EN_AccumulateWaterFlow_Timestamp"
"name": "s_Energy_PeriodEndingTimestamp"
"value": "Chiller #1 Ambient Temperature",
"name": "s_ExhaustFan1_Device"
"value": "04/12/2023 19:27:01",
"name": "s_ExhaustFan1_TemperatureFault_Timestamp"
"value": "",
"name": "s_Fault_LowOil_Timestamp"
"value": "04/10/2023 06:42:53",
"name": "s_Fault_Quincy30HP_Timestamp"
"value": "",
"name": "s_Fault_Quincy50HP_Timestamp"
"value": "",
"name": "s_Fault_QuincyRecip_Timestamp"
"value": "BNA Acid Silo",
"name": "s_HCLFeeders_Back_Device"
"value": "04/06/2023 07:34:05",
"name": "s_HCLFeeders_Back_DrumLevelLow_Timestamp"
"value": "Air Pump (Silo to 50gal Drum) Back",
"name": "s_HCLFeeders_Back_Pump_SiloTo50Gal_Description"
"value": "BNA_A2Acid",
"name": "s_HCLFeeders_Back_PumpName"
"value": "NORMAL",
"name": "s_HCLFeeders_Back_State"
"value": "Dept 5 / Robot Acid Silo",
"name": "s_HCLFeeders_Front_Device"
"value": "04/12/2023 14:01:52",
"name": "s_HCLFeeders_Front_DrumLevelLow_Timestamp"
"value": "Air Pump (Silo to 50gal Drum) Front",
"name": "s_HCLFeeders_Front_Pump_SiloTo50Gal_Description"
"value": "Dept5_A1Acid",
"name": "s_HCLFeeders_Front_PumpName"
"value": "NORMAL",
"name": "s_HCLFeeders_Front_State"
"value": "BNA A-1 Acid HCL Feed Pump",
"name": "s_HCLFeeders_Pump_BNA_A1Acid_Device"
"value": "BNA A-2 Acid HCL Feed Pump",
"name": "s_HCLFeeders_Pump_BNA_A2Acid_Device"
"value": "BNA Ni Strike HCL Feed Pump",
"name": "s_HCLFeeders_Pump_BNA_NiStrike_Device"
"value": "Dept. 5 A-1 Acid HCL Feed Pump",
"name": "s_HCLFeeders_Pump_Dept5_A1Acid_Device"
"value": "Dept. 5 A-2 Acid HCL Feed Pump",
"name": "s_HCLFeeders_Pump_Dept5_A2Acid_Device"
"name": "s_HCLFeeders_Pump_Dept8_A1Acid_Device"
"name": "s_HCLFeeders_Pump_Dept8_A2Acid_Device"
"value": "b_HCLFeedRuntime_Dept5_A1Acid_ClearWarning",
"name": "s_HCLFeeders_VariableName"
"value": "04/06/2023 07:38:09",
"name": "s_HCLFeedersStateError_Back_Timestamp"
"value": "04/12/2023 14:03:23",
"name": "s_HCLFeedersStateError_Front_Timestamp"
"value": "04/13/2023 07:33:50",
"name": "s_HCLFeedNeeded_BNA_A1Acid_Timestamp"
"value": "04/13/2023 08:08:40",
"name": "s_HCLFeedNeeded_BNA_A2Acid_Timestamp"
"value": "04/13/2023 08:34:39",
"name": "s_HCLFeedNeeded_BNA_NiStrike_Timestamp"
"value": "",
"name": "s_HCLFeedNeeded_Dept5_A1Acid_Timestamp"
"value": "",
"name": "s_HCLFeedNeeded_Dept5_A2Acid_Timestamp"
"value": "",
"name": "s_HCLFeedNeeded_Dept8_A1Acid_Timestamp"
"value": "",
"name": "s_HCLFeedNeeded_Dept8_A2Acid_Timestamp"
"value": "",
"name": "s_HCLFeedRuntime_BNA_A1Acid_Timestamp"
"value": "",
"name": "s_HCLFeedRuntime_BNA_A2Acid_Timestamp"
"value": "",
"name": "s_HCLFeedRuntime_BNA_NiStrike_Timestamp"
"value": "",
"name": "s_HCLFeedRuntime_Dept5_A1Acid_Timestamp"
"value": "",
"name": "s_HCLFeedRuntime_Dept5_A2Acid_Timestamp"
"value": "",
"name": "s_HCLFeedRuntime_Dept8_A1Acid_Timestamp"
"value": "",
"name": "s_HCLFeedRuntime_Dept8_A2Acid_Timestamp"
"value": "04/13/2023 07:28:19",
"name": "s_HistorizationWarning_Timestamp"
"value": "04/13/2023 00:00:00",
"name": "s_IndustrialWater_LastReset_Timestamp"
"value": "Industrial water gallons exceeded",
"name": "s_IndustrialWater_Warning_Description"
"value": "04/10/2023 02:45:20",
"name": "s_IndustrialWater_Warning_Timestamp"
"value": "gallons",
"name": "s_IndustrialWater_Warning_Units"
"value": "04/13/2023 07:27:46",
"name": "s_IOError_Timestamp"
"value": "",
"name": "s_kWhWarning_Timestamp"
"value": "",
"name": "s_LabRectifier_ElapsedTime"
"value": "",
"name": "s_LogData_LogTrigger"
"value": "",
"name": "s_LogData_ParseError"
"value": "12",
"name": "s_LogData_Value"
"value": "",
"name": "s_MonitorAirCompressorPM_Trigger"
"value": "b_Chiller3Compressor2_TemperatureFault",
"name": "s_MonitorChillerFaults_VariableName"
"value": "3",
"name": "s_MonitorChillerRunTimes_Chiller"
"value": "Chiller3Compressor2",
"name": "s_MonitorChillerRunTimes_ChillerCompressor"
"value": "2",
"name": "s_MonitorChillerRunTimes_Compressor"
"value": "04/09/2023 07:00:03",
"name": "s_MonitorChillerRunTimes_Timestamp"
"value": "rst_Chiller3Compressor2_WeeklyTimestamps",
"name": "s_MonitorChillerRunTimes_VariableName"
"value": "dt_MonitorIO_R1_202",
"name": "s_MonitorIO_Variable"
"name": "s_MonitorSumpPumps_SumpName"
"value": "b_Dept5_Lane2SumpFloatWarning_ClearWarning",
"name": "s_MonitorSumpPumps_VariableName"
"value": "b_Dept5_Lane2SumpLevelWarning_Log",
"name": "s_MonitorTriggers_LogVariableName"
"value": "",
"name": "s_MonitorTriggers_Trigger"
"value": "s_ChartRuntimeError_Timestamp",
"name": "s_MonitorTriggers_VariableName"
"value": "Dept 3 Chiller",
"name": "s_NeedDept3Chiller_Device"
"value": "04/07/2023 18:44:38",
"name": "s_NeedDept3Chiller_Timestamp"
"value": "Dept 5 Chiller",
"name": "s_NeedDept5Chiller_Device"
"value": "04/10/2023 05:04:09",
"name": "s_NeedDept5Chiller_Timestamp"
"value": "",
"name": "s_PMNeeded_Quincy30HP_Timestamp"
"value": "",
"name": "s_PMNeeded_Quincy50HP_Timestamp"
"value": "",
"name": "s_PMNeeded_Quincy75HP_Timestamp"
"value": "",
"name": "s_PMNeeded_QuincyRecip_Timestamp"
"name": "s_PotableWater_LastReset_Timestamp"
"value": "Potable water gallons exceeded",
"name": "s_PotableWater_Warning_Description"
"value": "04/10/2023 04:50:21",
"name": "s_PotableWater_Warning_Timestamp"
"value": "gallons",
"name": "s_PotableWater_Warning_Units"
"value": "04/13/2023 07:00:00",
"name": "s_PreviousDayEnd"
"value": "04/13/2023 07:00:01",
"name": "s_PreviousShiftEnd"
"value": "04/09/2023 00:00:01",
"name": "s_PreviousWeekEnd"
"value": "Quincy 30HP Supplemental Compressor",
"name": "s_Quincy30HP_Device"
"value": "Quincy 50HP Primary Compressor",
"name": "s_Quincy50HP_Device"
"value": "Quincy 75HP Manual Compressor",
"name": "s_Quincy75HP_Device"
"value": "Quincy Reciprocating Auxiliary Compressor",
"name": "s_QuincyRecip_Device"
"value": "",
"name": "s_Recipes_Status"
"value": "",
"name": "s_RecipUsageWarning_Timestamp"
"value": "",
"name": "s_ROFault_Timestamp"
"value": "RO Water Tank",
"name": "s_ROLevelWarning_Device"
"value": "",
"name": "s_ROLevelWarning_Timestamp"
"value": "04/12/2023 12:12:24",
"name": "s_SaltSprayTemperatureWarning_Timestamp"
"value": "",
"name": "s_SodiumSulfite_HighLevel_Timestamp"
"value": "04/10/2023 06:08:14",
"name": "s_SupplementalAirNeeded_Timestamp"
"value": "04/13/2023 06:23:26",
"name": "s_SynchronizeControllerClock_Timestamp"
"value": "",
"name": "s_TestWarnings_Trigger"
"value": "",
"name": "s_TestWarnings_VariableName"
"value": "3 PHASE POWER MAY BE OFF",
"name": "s_TriggerDescription_3PhaseWarning"
"value": "75HP SCREW RUNTIME LIMIT EXCEEDED",
"name": "s_TriggerDescription_75HPRuntimeWarning"
"value": "A/A SUMP IS TOO HIGH - WATER NEEDS TO BE SHUT OFF",
"name": "s_TriggerDescription_AASumpLevelShutdown"
"value": "A/A SUMP IS TOO HIGH - CHECK PUMP FOR OPERATION",
"name": "s_TriggerDescription_AASumpLevelWarning"
"value": "A PLANT AIR TEMP PROBE IS NOT WORKING",
"name": "s_TriggerDescription_AirMakeup_ProbeQualityWarning"
"value": "PLANT AIR TEMPERATURE IS TOO LOW (WEEKEND)",
"name": "s_TriggerDescription_AirMakeup_TemperatureWarning"
"value": "AIR PRESSURE HIGH: AUXILIARY",
"name": "s_TriggerDescription_AirPressureHigh_Auxiliary"
"value": "AIR PRESSURE HIGH: PLANT",
"name": "s_TriggerDescription_AirPressureHigh_Plant"
"value": "AIR PRESSURE LOW: AUXILIARY",
"name": "s_TriggerDescription_AirPressureLow_Auxiliary"
"value": "AIR PRESSURE LOW: PLANT",
"name": "s_TriggerDescription_AirPressureLow_Plant"
"value": "BEAD BLASTER OFF - NO MOTION",
"name": "s_TriggerDescription_BeadBlasterNoMotionWarning"
"value": "A FLAME FAILURE HAS OCCURED ON BOILER #1",
"name": "s_TriggerDescription_Boiler1_FlameFailure"
"value": "BOILER #1 WATER LEVEL IS LOW",
"name": "s_TriggerDescription_Boiler1_LowWaterLevel"
"value": "A FLAME FAILURE HAS OCCURED ON BOILER #2",
"name": "s_TriggerDescription_Boiler2_FlameFailure"
"value": "BOILER #2 WATER LEVEL IS LOW",
"name": "s_TriggerDescription_Boiler2_LowWaterLevel"
"value": "BOILER PRESSURE IS OUTSIDE OPERATIONAL LIMITS",
"name": "s_TriggerDescription_BoilerPressure_Warning"
"value": "BOILERS ARE ON DURING THE WEEKEND",
"name": "s_TriggerDescription_BoilersOnDuringWeekend"
"value": "BOILER WATER FEED ON WITH NO BOILERS (WEEKEND)",
"name": "s_TriggerDescription_BoilerWater_NoBoilers"
"value": "BOILER WATER FEED ON TOO LONG (WEEKEND)",
"name": "s_TriggerDescription_BoilerWater_OnTooLong"
"value": "CHART RUNTIME ERROR",
"name": "s_TriggerDescription_ChartRuntimeError"
"value": "DAILY ALLOWED LEVEL DECREASE EXCEEDED",
"name": "s_TriggerDescription_ChilledTank1_DailyDecrease"
"value": "HOURLY ALLOWED LEVEL DECREASE EXCEEDED",
"name": "s_TriggerDescription_ChilledTank1_HourlyDecrease"
"value": "THE CHILLED WATER TANK LEVEL IS LOW",
"name": "s_TriggerDescription_ChilledTank1_LevelLow"
"value": "MEZZ CHILLED TANK TEMPERATURE IS HIGH",
"name": "s_TriggerDescription_ChilledTank1_TemperatureFault"
"value": "DEPT 3 CHILLED TANK TEMPERATURE IS HIGH",
"name": "s_TriggerDescription_ChilledTank2_TemperatureFault"
"value": "A CHILLER COMPRESSOR HAS FAULTED",
"name": "s_TriggerDescription_ChillerCompressorFault"
"value": "A CHILLER IS ON, BUT IS NOT NEEDED",
"name": "s_TriggerDescription_ChillerNotNeeded"
"value": "A COMPRESSOR MODULE HAS FAULTED",
"name": "s_TriggerDescription_CompressorModuleFault"
"value": "DEPT 5 LANE 1 SUMP IS TOO HIGH - SHUT OFF WATER",
"name": "s_TriggerDescription_Dept5_Lane1SumpFloatWarning"
"value": "DEPT 5 LANE 1 SUMP IS TOO HIGH - CHECK OPERATION",
"name": "s_TriggerDescription_Dept5_Lane1SumpLevelWarning"
"value": "DEPT 5 LANE 2 SUMP IS TOO HIGH - SHUT OFF WATER",
"name": "s_TriggerDescription_Dept5_Lane2SumpFloatWarning"
"value": "DEPT 5 LANE 2 SUMP IS TOO HIGH - CHECK OPERATION",
"name": "s_TriggerDescription_Dept5_Lane2SumpLevelWarning"
"value": "CHILLER EXHAUST FAN TEMPERATURE IS HIGH",
"name": "s_TriggerDescription_ExhaustFan1_TemperatureFault"
"value": "LOW OIL FAULT: QUINCY RECIP",
"name": "s_TriggerDescription_Fault_LowOil"
"value": "COMPRESSOR FAULT: QUINCY 30HP",
"name": "s_TriggerDescription_Fault_Quincy30HP"
"value": "COMPRESSOR FAULT: QUINCY 50HP",
"name": "s_TriggerDescription_Fault_Quincy50HP"
"value": "COMPRESSOR FAULT: QUINCY RECIP",
"name": "s_TriggerDescription_Fault_QuincyRecip"
"value": "50 GALLON FEED DRUM LEVEL LOW - BACK",
"name": "s_TriggerDescription_HCLFeeders_Back_DrumLevelLow"
"value": "50 GALLON FEED DRUM LEVEL LOW - FRONT",
"name": "s_TriggerDescription_HCLFeeders_Front_DrumLevelLow"
"value": "HCL FEEDER STATE & HOIST STATE IS INCOMPATIBLE",
"name": "s_TriggerDescription_HCLFeedersStateError_Back"
"name": "s_TriggerDescription_HCLFeedersStateError_Front"
"value": "BNA A-1 ACID HCL FEED NEEDED",
"name": "s_TriggerDescription_HCLFeedNeeded_BNA_A1Acid"
"value": "BNA A-2 ACID HCL FEED NEEDED",
"name": "s_TriggerDescription_HCLFeedNeeded_BNA_A2Acid"
"value": "BNA NI STRIKE HCL FEED NEEDED",
"name": "s_TriggerDescription_HCLFeedNeeded_BNA_NiStrike"
"value": "DEPT5 A-1 ACID HCL FEED NEEDED",
"name": "s_TriggerDescription_HCLFeedNeeded_Dept5_A1Acid"
"value": "DEPT5 A-2 ACID HCL FEED NEEDED",
"name": "s_TriggerDescription_HCLFeedNeeded_Dept5_A2Acid"
"value": "DEPT8 A-1 ACID HCL FEED NEEDED",
"name": "s_TriggerDescription_HCLFeedNeeded_Dept8_A1Acid"
"value": "DEPT8 A-2 ACID HCL FEED NEEDED",
"name": "s_TriggerDescription_HCLFeedNeeded_Dept8_A2Acid"
"value": "BNA A-1 ACID HCL FEED RUNTIME",
"name": "s_TriggerDescription_HCLFeedRuntime_BNA_A1Acid"
"value": "BNA A-2 ACID HCL FEED RUNTIME",
"name": "s_TriggerDescription_HCLFeedRuntime_BNA_A2Acid"
"value": "BNA NI STRIKE HCL FEED RUNTIME",
"name": "s_TriggerDescription_HCLFeedRuntime_BNA_NiStrike"
"value": "DEPT5 A-1 ACID HCL FEED RUNTIME",
"name": "s_TriggerDescription_HCLFeedRuntime_Dept5_A1Acid"
"value": "DEPT5 A-2 ACID HCL FEED RUNTIME",
"name": "s_TriggerDescription_HCLFeedRuntime_Dept5_A2Acid"
"value": "DEPT8 A-1 ACID HCL FEED RUNTIME",
"name": "s_TriggerDescription_HCLFeedRuntime_Dept8_A1Acid"
"value": "DEPT8 A-2 ACID HCL FEED RUNTIME",
"name": "s_TriggerDescription_HCLFeedRuntime_Dept8_A2Acid"
"value": "HISTORIZATION ERROR",
"name": "s_TriggerDescription_HistorizationWarning"
"value": "INDUSTRIAL WATER FEED EXCEEDED GALLONS LIMIT",
"name": "s_TriggerDescription_IndustrialWater_Warning"
"value": "I/O ERROR",
"name": "s_TriggerDescription_IOError"
"value": "15 MINUTE KWH LIMIT EXCEEDED",
"name": "s_TriggerDescription_kWhWarning"
"value": "THE DEPT 3 CHILLER IS OFF BUT SHOULD BE ON",
"name": "s_TriggerDescription_NeedDept3Chiller"
"value": "THE DEPT 5 CHILLER IS OFF BUT SHOULD BE ON",
"name": "s_TriggerDescription_NeedDept5Chiller"
"value": "POTABLE WATER FEED EXCEEDED GALLONS LIMIT",
"name": "s_TriggerDescription_PotableWater_Warning"
"value": "RECIP COMPRESSOR USAGE LIMIT EXCEEDED",
"name": "s_TriggerDescription_RecipUsageWarning"
"value": "RO SYSTEM FAULT",
"name": "s_TriggerDescription_ROFault"
"value": "RO STORAGE TANK LEVEL OUT OF LIMITS",
"name": "s_TriggerDescription_ROLevelWarning"
"value": "SALT SPRAY TEMPERATURE OUT OF LIMITS",
"name": "s_TriggerDescription_SaltSprayTemperatureWarning"
"value": "SODIUM SULFITE FEED TANK LEVEL IS HIGH",
"name": "s_TriggerDescription_SodiumSulfite_HighLevel"
"value": "SUPPLEMENTAL AIR COMPRESSOR NEEDED",
"name": "s_TriggerDescription_SupplementalAirNeeded"
"value": "DEPT 3 NZ ZINC PERCENT IS INCORRECT",
"name": "s_TriggerDescription_ZincNickelPercentWarning"
"value": "",
"name": "s_ZincNickelPercentWarning_Timestamp"
