Hello, I work at a place which is using a SNAP-PAC-R1 firmware version 8.5c. I need to make a small change to I believe what is called a persistent variable. I literally just need to change the value from the integer 4 to 2. It doesn’t seem like there is a straightforward way to do this and when I cross reference the variables I can’t see where a value is moved into the variable. I’ve looked at a couple of persistent variables and it seems like they were somehow set and then downloaded the controller. What is the easiest way to change a persistent variable from one value to another?
