As I pondered some of the ideas and suggestions in this post about the magic Opto number: -32768 … I tried to use an analog point in my Condition block with the Float Valid? command and it wouldn’t let me select an analog point. ![]()
Luckily, I learned that in PAC Control R9.1a or newer, you can skip the extra step of copying that point to a float before testing it, if you use the OptoScript equivalent: IsFloatValid, perhaps like this:
if ( IsFloatValid( my_analog_point ) ) then
// that's a good sign
else
// we might have a problem, do something here
endif
