I need the output of the PLC of a screen printing machine to capture the cycles of operation, the output is used to energize a valve that is used to enable the vaccuum system, this valve is of 2 watts, the question is if there a problem to connect this output to the input of my groove rio. The question is because I don´t want to damage the module, theorically the current should be 0.083 amperes.
I already create a flow using a counter node and works fine in my desk simulating the signal but I need to use it in the field. Please advise
thanks in advance.
