I am trying to put together an NTP timestamp to use as a key for data logging. The documentation on NTP functions are clear as mud… I am getting a negative number which according to the documentation means there is an error somewhere. Does this look right?
NTP timestamps are unsigned int64, since integers in PAC Control are signed and the current NTP timestamp has a 1 in the most significant bit, it will be negative - this is correct and not an error.
That didn’t help much. I don’t care about UUID. Just a straight NTP is fine. From what I have gathered, my commands are correct… I think… the document commands don’t exactly match what PAC Control uses. Yes, “NTP_Timestamp” is int64. Optoscript let me know it was wrong on a test compile.
That documentation is wrong - I’ve reported this and I think it has been fixed. nResult is not supposed to be a parameter, what you have in your Optoscript window is correct.
