I was trying to use the SNAP PAC Write Node to update a particular index of a table. I see you can specify this in the node, but is there a way to specify this from a variable in the payload? My flow will not know which index to write to at design time.
Oh good, very very good. I’ll have to revisit that. One issue I have with Node-RED is that I am ALWAYS sitting on the Debug window, so I kind of forget about the info tab. (And a lot of nodes are just poorly documented, so the info tab isn’t really useful a lot of the time.)
