Node Red - Randomly stopping
Good day,
Having a issue with Node-Red on a Epic PR1.
My flows randomly stop doin what they meant to.
I have a 5 second inject node that runs the flows. All work great until my client calls and says data is not logging in SQL.
I connect remotely, go to groov manage, move a node and deploy. That is all and it will work for a couple of days and same.
Any insight into possible remedies ?
Regards
Robin
Before you remote in, do the wiggle and re-deploy, what do the Node-RED logs show?
If you know the time it last happen, the logs still might be there.
