Node-Red Opto22 Error documentation
Since the Node-RED node simply uses the REST interface, you can find all your error codes in the (back of the) PAC Control users guide.
It states as much at the bottom of the ‘info’ tab in Node-RED (Don’t panic, you would not be the first to miss it).
I can recommend using the Catch Node while you are getting things sorted, its helpful in all sorts of flows.
