Error trying to add nodes… wanted: {“node”:“>=16”} (current: {“node”:“14.20.0”,“npm”:“6.14.17”}
Is there a way to properly update the RIO to a more current version or is it coming soon as default?
The engineers are working hard on a major new firmware version for both EPIC and RIO.
Till then, use the groov Manage Node tool to install an older version of the node that does not require node 16.
Thanks I will try that
How do I select a version older than what is presented. “node-red-contrib-web-worldmap”
Here you find a complete list of the versions for that Node.
In groov Manage/Node-RED you find under Advanced “Node Management”
Click on it and enter the Node Name and the Version you want to install.
Awesome,
Thanks got it
