Is it possible to dynamically set the values of the module/channel index fields for the Groov I/O nodes?
Fairly sure I know the answer is no. But want to ask just in case I’m missing something.
I am trying to handle incoming HTTP requests that have an asphalt silo number in the payload. It would be great to dynamically set the module/channel index based on the payload so I could have 1 flow to trigger N number of silos instead of needing to configure 1 flow per silo.
