Node is installed but still appearing as unknown in the flow
I have “node-red-contrib-s7” installed in my pallet but still it is appearing as unknown node. need help!
below is the code.
[{“id”:“af432f72.2f9988”,“type”:“s7comm-read”,“z”:“64b0d45a.f0da9”,“server”:“b39be4a3.b76f78”,“name”:“Read Bit 1”,“dataItem”:“I1.1”,“areaId”:“inputs”,“areaType”:“input”,“dataType”:“Boolean”,“quantity”:1,“addressOffset”:0,“quantityType”:“BIT”,“timeout”:1000,“rbe”:false,“x”:210,“y”:160,“wires”:[[“5250e516.2f77e4”]]},{“id”:“4579aaf5.2e09c”,“type”:“s7comm-read”,“z”:“64b0d45a.f0da9”,“server”:“b39be4a3.b76f78”,“name”:“Read Bit 2”,“dataItem”:“I1.2”,“areaId”:“inputs”,“areaType”:“input”,“dataType”:“Boolean”,“quantity”:1,“addressOffset”:0,“quantityType”:“BIT”,“timeout”:1000,“rbe”:false,“x”:210,“y”:220,“wires”:[[“5250e516.2f77e4”]]},{“id”:“5250e516.2f77e4”,“type”:“function”,“z”:“64b0d45a.f0da9”,“name”:“Count Positive Edge”,“func”:“var counter1 = flow.get(‘counter1’) || 0;\nvar counter2 = flow.get(‘counter2’) || 0;\n\nif (msg.topic === ‘bit1’) {\n if (msg.payload === true) {\n counter1++;\n }\n flow.set(‘counter1’, counter1);\n}\n\nif (msg.topic === ‘bit2’) {\n if (msg.payload === true) {\n counter2++;\n }\n flow.set(‘counter2’, counter2);\n}\n\nreturn msg;”,“outputs”:1,“noerr”:0,“initialize”:“”,“finalize”:“”,“x”:450,“y”:190,“wires”:[[“6d42f53a.9795f4”,“d4d53f6e.5d55e8”]]},{“id”:“6d42f53a.9795f4”,“type”:“change”,“z”:“64b0d45a.f0da9”,“name”:“Combine Counters”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“{\t "counter1": flow.get(‘counter1’),\t "counter2": flow.get(‘counter2’)\t}”,“tot”:“jsonata”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:650,“y”:190,“wires”:[[“d9a5c474.f34b3”]]},{“id”:“d9a5c474.f34b3”,“type”:“csv”,“z”:“64b0d45a.f0da9”,“name”:“Format as CSV”,“sep”:“,”,“hdrin”:true,“hdrout”:true,“multi”:“one”,“ret”:“\n”,“temp”:“”,“skip”:“0”,“strings”:true,“x”:840,“y”:190,“wires”:[[“35f19a6c.7e9c66”]]},{“id”:“35f19a6c.7e9c66”,“type”:“file”,“z”:“64b0d45a.f0da9”,“name”:“Save to CSV”,“filename”:“/path/to/your/file.csv”,“appendNewline”:true,“createDir”:false,“overwriteFile”:“false”,“encoding”:“none”,“x”:1030,“y”:190,“wires”:[]},{“id”:“d4d53f6e.5d55e8”,“type”:“ui_text”,“z”:“64b0d45a.f0da9”,“group”:“72428733.d7f27c”,“order”:1,“width”:0,“height”:0,“name”:“”,“label”:“Counter Value”,“format”:“Counter 1: {{msg.payload.counter1}} | Counter 2: {{msg.payload.counter2}}”,“layout”:“row-spread”,“x”:820,“y”:250,“wires”:},{“id”:“b39be4a3.b76f78”,“type”:“s7comm-server”,“z”:“”,“port”:“102”,“rack”:0,“slot”:2,“localTSAP”:“02:01”,“remoteTSAP”:“01:00”,“localCpuSlot”:2,“sendTimestamps”:false,“cycleTime”:1000,“timeout”:1000,“showErrors”:false,“x”:120,“y”:80,“wires”:},{“id”:“72428733.d7f27c”,“type”:“ui_group”,“name”:“Counter”,“tab”:“5e2e7a6e.1eb1f8”,“order”:1,“disp”:true,“width”:“6”,“collapse”:false},{“id”:“5e2e7a6e.1eb1f8”,“type”:“ui_tab”,“name”:“Dashboard”,“icon”:“dashboard”,“order”:1,“disabled”:false,“hidden”:false}]
type or paste code here
Did you restart Node-RED from groov Manage?
Was there any indication that it did not install correctly in the log at the time of adding it to your pallet?
Is it in the list of nodes in the left hand panel?
What does the Manage Pallet tab show it as?
