Moving App From Groov to PAC Control
I want to be able to create a tag from a third-party PLC (ABB PM564-Eth) in PAC Control. I can do it in Groov easily by setting up a Modbus device and adding a tag with an address that’s been setup on my ABB environment (Application Builder/CoDeSys). Easy and works like a champ. How do I do that in PAC Control?
I have the Modbus Integration Kit and I can write other Modbus devices by using the Function 06 routine but it doesn’t work for my PLC. But the Groov works fine so I think I must be doing something wrong in PAC Control.
I this belongs in the Groov forum, please let me know.
Dave
If you are able to read/write it from Groov, I think you should be able to read/write it from the PAC. Is this Modbus TCP? Can you post the parameter values you are using to call the Modbus subroutine?
I didn’t see your reply until now so I’ve been spending a little more time with this and using Modscan32 I can see that I am able to write the variable, it just doesn’t show up in the ABB CoDeSys. That’s probably because of my ignorance of that environment.
In any case thanks for your help!
Dave
