I need to modify the Modbus integration strategy to accommodate IEEE 754 Float (32 bit) from a Watlow F4T Temperature Humidity controller.
Thought i would check here for some ideas before I jump headlong into this and change my brain chemistry forever…
Has anyone started this project already?
                Beno
                    October 26, 2020,  7:37pm
                  2
              What controller are you using?
              Snap S2 and an SCM serial Module in position 0 with and EB2.
                Beno
                    October 26, 2020,  7:49pm
                  4
              Paging Dr @philip  to the thread.
                philip
                    October 26, 2020,  9:32pm
                  5
              It’s been a while since I’ve used the integration kit, but I thought it already handled floats? Is there a particular issue you are having with it?
                LadyBNC
                    October 26, 2020, 10:00pm
                  6
I can not seem to get it to work with IEEE 754 single precision signed floats.
16 bit works fine. Ill check my parameters again.
                philip
                    October 26, 2020, 11:09pm
                  7
              Try using data type 3 in the integration kit - which is for the least significant 16 bits in the lower register. I think that is the default for your device.
